How to select connection type and application in Post-installed rebar module
Selecting the correct connection type and application ensures that PROFIS Engineering applies the appropriate design assumptions for geometry, load transfer, and detailing. These settings help define the structural scenario so your Post-installed rebar design reflects the actual project conditions.
  • Have opened the Post-installed rebar module
If needed, refer to the article How to access the Post-installed rebar module in PROFIS Engineering.
  1. Open the Application tab
    In your Post-installed rebar design workspace, go to the Application tab located on the left-hand side of the screen.
  2. Select connection type
    Under Connections & Applications, choose the Connection type that best fits your design scenario.
  3. Select an application
    Under Connections & Applications, select the appropriate Application for your chosen connection type.
    The available applications will update depending on the selected connection type.
    If applicable, you can also enable Extension at support or Continuous in X direction.
  4. Rotate 3D model (Optional)
    Under 3D Model rotation, use the rotation controls to turn the 3D model. Each click rotates the model by 90 degrees.
