About PROFIS Engineering
PROFIS Engineering is Hilti’s cloud‑based structural design software that enables you to design, check, and document a wide range of fastening and connection applications. The platform integrates multiple design modules, including Anchoring to Concrete, Concrete‑to‑Concrete, Masonry, Facade, and other structural workflows, using globally recognised design standards. PROFIS Engineering streamlines your workflow by guiding you through code‑compliant design steps, offering automated design suggestions, and generating professional engineering reports.
Before you begin using PROFIS Engineering, make sure you have:
  • A valid Hilti account
  • Access to https://profisengineering.hilti.com
  • A stable internet connection
  • (Optional) A PROFIS Engineering Premium subscription to unlock advanced features
Step-by-Step Instructions
  1. Access PROFIS Engineering
    Go to: https://profisengineering.hilti.com and log in with your Hilti credentials.
  2. Explore available design modules on the home page
    From the landing page, you can select the design module that fits your application, such as:
    • Anchoring to Concrete
    • Anchoring to Masonry
    • Post-installed rebar
    • Concrete overlay
    • Facade
    • Anchor channel
    • Shear strengthening
    • Punching shear strengthening
    • Handrail
    • Seismic masonry reinforcement
    • Shear Connector Design
      (Availability depends on region.)
  3. Start a new design
    Click New → Custom design, choose the appropriate fixing type, and configure your design settings such as region, units, and design method.
  4. Use the design workspace
    Each module provides a guided interface that includes:
    • A 3D/2D editor for geometry and load definition
    • Tabs for base materials, anchors, profiles, installation conditions, reinforcement, and design methods
    • A Results & Notifications panel for design checks, warnings, and optimization prompts
    • Export options for reports, templates, and design files
  5. Generate your engineering report
    Once your design is complete, click Generate report to produce a detailed calculation document, including inputs, checks, and results.
    Note: To customise your report template go to Profile → My report templates.
Before starting your first design, set your preferred region, units, and default design methods under Settings → General. This ensures every new project automatically uses your preferred standards and reduces the need for repeated configuration.
