How to use the 3D Editor in Facade module
The 3D view allows you to adjust the visual orientation of your model, edit geometry directly, apply loads, and select products - all within an interactive 3D environment.
If needed, refer to the article How to access the Facade module in PROFIS Engineering.
  1. Modify dimensions
    In the 3D view, click directly on any dimension label to edit.
  2. Input loads
    Click on the tension or shear load labels in the 3D view to enter load values.
  3. Select product
    Click the product selector box in the top right corner of the 3D view to choose the product type, size, embedment depth, and to view product approval data.
  4. Modify the view
    Rotate: Left‑click and drag anywhere in the 3D view.
    Pan: Right‑click and drag to shift the model.
Use Show/hide elements in 3D to control what is displayed.
For more details, refer to the article Navigating the landing page to familiarise yourself with all available controls.
