How to search for a design file in a project
Searching for a design file within a project helps you quickly locate specific designs without manually browsing through multiple folders. This feature allows you to filter project contents efficiently, making it easier to access the exact file you need, especially in projects containing many design variations.
  3. Go to your project
    In the PROFIS Engineering home page, go to My projects on the left-hand side of the screen and click on your project folder.
  4. Searching the project folder
    Navigate to the search bar under All designs and search for the design file.
    Choose to view the search results either in grid view or list view.
  5. Sort the design files
    Click on Sort and select a suitable option from the dropdown list to sort the design files.
Use meaningful keywords such as part of the file name, project reference, or connection type to refine your search results. Maintaining consistent naming conventions for each design file will make searching faster and more accurate.
