How to modify eccentricity of attachment profile in Anchoring to Masonry module
0
Modifying the eccentricity of the attachment profile allows PROFIS Engineering to correctly account for the offset between the applied loads and the anchor group’s centroid. Adjusting eccentricity ensures that the software applies the appropriate actions, resulting in more accurate representation of how the connected profile transfers loads into the baseplate and anchors.
  1. Open the Profiles tab
    In your Anchoring to Masonry design workspace, navigate to the Profiles tab on the left-hand side of the screen.
  2. Go to Eccentricity
    Here you can type in the eccentricity values or use the “+ / –” controls to increase or decrease it. You can input load eccentricity values also without profile enabled.
  3. Modify the attachment angle
    When Use profile is enabled, navigate to Angle to adjust the angle of the attachment profile.
