Navigating the landing page for Anchor channel module
Upon logging into PROFIS Engineering module, the 3D model is displayed centrally within the workspace. The left panel is designated for entering design inputs, the bottom panel facilitates the management of load combinations, and the right panel presents results, notifications, and options for generating design reports, specification texts, as well as basic import/export functionalities.
Overview of the interface
Home button
My favorite inputs
Save and access commonly used design inputs.
Application
Select the application type and fastening technology.
Plate
Enter information related to plate shape, size, stand-of, position of the flange (if any), and eccentricity.
Concrete member
Enter information related to concrete type, grade, geometry, temperature, installation conditions, and borehole condition.
Concrete reinforcement
Specify supplementary reinforcement.
Product
Define product and layout.
Load/calculation type
Select load type, load definition, design method and channel tolerance (if applicable).
Firestop selection
Discover how Hilti can help you prevent fire spreading, by correctly using a firestop solution at the edge of the slab behind your curtain wall.
Bottom panel (Load combinations)
Use this panel to input, edit, and manage load combinations acting on the connection.
Export
Export your design in a variety of formats.
Duplicate
Create duplicate copy of your design.
Importing existing file
Anchor loads / Bolt loads
Expand to view loads acting on the bolt and anchor.
Anchor design
Expand to view design checks and utilization results.
Messages
View design tips, watchouts and system messages.
Top panel (Settings & tools)
Settings
Modify design method, units and safety factors.
Save as template
Support
Learn
Updates
Profile
View your profile, manage your account, view legal documents and sign out.
Central panel (3D view)
The 3D model of your design is displayed in this area. You can adjust the view, modify geometry, apply loads, and select products directly within the 3D environment.
Reset camera
Return the model to the default viewing position.
Show/hide elements on 3D
Control what is displayed in 3D view.
Undo
Reverse the previous action.
Redo
Zoom to fit
Automatically fit the entire model within the screen.
Product selector
Select product type, embedment depth, channel length, and view product approval information.
Collapse menu
Collapse or expand the left-hand, right-hand or bottom panel for more workspace visibility.
Zoom
Zoom in or out of the 3D model.
