How to select load type and design method in Anchor channel module
Selecting the correct load type and design method ensures that PROFIS Engineering applies the appropriate assumptions for load behavior, design checks, and calculation models. These settings directly influence how loads are interpreted and how anchor forces, failure modes, and design capacities are evaluated.
  • Have entered all design inputs
  1. Go to Loads / Calculation Type
    In your Anchor channel design workspace, go to the Load type tab on the left-hand side of the screen.
  2. Select the Load type
    Go to Load type and select the desired option.
    The Static load option is enabled by default.
  3. Define Seismic load type (if applicable)
    Go to Load type and select the seismic load option.
    Select the seismic tension type from available options.
    Select the seismic shear type from available options.
  4. Select load input type
    Go to Load definition and choose suitable load input type from available options.
  5. Select the design method
    Go to the Design method and choose the desired option from the dropdown menu.
  6. Define Tolerance
    Go to Tolerance and select the suitable option from dropdown menu.
    Note:
    • This section in enabled only for Anchor channels and Cast-in anchors.
    • The dropdown menu for Tolerance in slotted hole in/out becomes visible only when Load per plate input type is selected.
For guidance on firestop, click on Firestop selection tab on the left-hand side of the screen.
