How to access the Facade module in PROFIS Engineering
You need to access the Facade module before you can define materials, modify geometry, or run design calculations. This article explains how to open the module to start your design workflow.
Make sure you have:
  • A valid Hilti account
  • Access to PROFIS Engineering
  • A stable internet connection
  1. Go to the PROFIS Engineering website
  2. Log in to your account
    Enter your Hilti credentials to access your workspace.
  3. Open the Facade module
    Click New in the top-left corner.
    From the available options, select Custom design.
  1. Select the fixing type
    Choose Facade from the fixing type options.
  2. Customize settings (optional)
    If needed, adjust:
    • Calculation method and approvals
    • Units and default parameters
    Click Save once finished.
  3. Start a new design
    After selecting the fixing type, your Facade design workspace will load automatically.
Alternative access method
On the PROFIS Engineering home page, you can also click the Facade tile directly under the Applications section in the center panel.
Tips
Module availability depends on your region and permissions. Contact your local Hilti representative if you cannot access the module.
