How to define and modify geometry of the base material in Facade module
Defining and modifying the concrete geometry ensures that PROFIS Engineering uses the correct member thickness and edge distances for accurate fastening design and realistic load‑transfer behavior.
If needed, refer to the article How to access the Facade module in PROFIS Engineering.
  1. Open the Concrete material tab
    In your Facade design workspace, navigate to the Concrete material tab on the left-hand side of the screen.
  1. Go to Geometry
    Here you can type in the concrete thickness value and edge distances in x and y directions. Alternatively, use the “+ / –” controls to increase or decrease the values.
  2. Use the infinity edge option
    Select the Infinity edge option in case of large edge distances.
Changes to concrete thickness or edge distances can affect available design space and may trigger warnings or automatic updates in later steps.
