How to duplicate PROFIS design file in Facade module
0 0
Duplicating a PROFIS Engineering design file allows you to create a copy of an existing design so that you can explore alternative solutions, revise inputs, or generate variations without modifying the original file.
If needed, refer to the article How to access the Facade module in PROFIS Engineering.
  1. Click the Duplicate icon
    In your Facade design workspace, go to the panel on the right-hand side of the screen and click the Duplicate icon.
  2. Duplicate the file
    A new copy of your design file will be created automatically.
    The duplicated file will appear in a new window, which you can rename later if needed.
