How to define and modify supplementary reinforcement in Anchoring to Concrete module
Supplementary reinforcement significantly enhances anchor capacity restraining concrete breakout, particularly for shear near edges or high-tension loads. Providing information on supplementary reinforcement allows PROFIS Engineering to apply more realistic assumptions for concrete behavior.
  1. Open the Reinforcement tab
    In your Anchoring to Concrete design workspace, navigate to the Reinforcement tab on the left-hand side of the screen.
  1. Go to Supplementary reinforcement:
    • Select the suitable Supplementary reinforcement option from dropdown menu.
    • When either the Tension supplementary reinforcement or Shear supplementary reinforcement option is selected, reinforcement details need to be added.
PROFIS Engineering defaults to the assumption that supplementary reinforcement is not present. To account for the beneficial effects of supplementary reinforcement, please adjust the above options accordingly.
