How to modify baseplate position in Anchoring to Concrete module
Modifying the baseplate position in PROFIS Engineering allows you to rotate the baseplate to match the required orientation of the connection.
  1. Open the Baseplate tab
    In your Anchoring to Concrete design workspace, navigate to the Baseplate tab on the left-hand side of the screen.
  1. Go to Baseplate position
    Use rotation controls to turn the baseplate left or right. Each click rotates the plate by 90 degrees.
