How to use the 2D Editor in Anchoring to Concrete module
The 2D view allows you to adjust anchor layout and baseplate shape, edit geometry directly, and select products - all within an interactive 2D environment.
  • Have enabled the 2D editor
  1. Modify dimensions
    In the 2D view, click directly on any dimension label to edit it.
  2. Modify anchor layout
    Open Layout on the left-hand panel.
    Go to Anchor layout.
    Select from standard layouts or create custom layout.
    Tip: You can adjust your grid settings here.
  3. Modify baseplate shape
    Go to Plate shape.
    Choose a standard baseplate shape or ledger angle.
  4. Modify anchor and baseplate nodes
    Select Modify coordinates on the left-hand panel.
    Navigate to Anchor nodes or Baseplate nodes to edit or add nodes.
    Choose the coordinate reference point: Baseplate, Profile or Custom.
    You can also add or delete nodes and anchors directly in the 2D editor using the Add node, Add anchor, or Delete buttons in the top toolbar.
  5. Select product
    Click the product selector box in the top right corner of the 2D view to choose the product type, size, embedment depth, and to view product approval data.
  6. Modify the view
    Pan: Click the Pan model button to drag and reposition the model.
    Geometry mode: Toggle between symmetric and asymmetric geometry configurations as needed.
Use Show/hide elements in 2D to control what is displayed.
For more details, refer to the article Navigating the landing page to familiarise yourself with all available controls.
