How to optimise your design in Anchoring to Concrete module
Optimising your design allows you to improve anchor performance by adjusting key parameters such as anchor layout or baseplate dimensions. Small changes to these inputs can help you achieve a more efficient design.
  1. Input design parameters
    In your Anchoring to Concrete design workspace, enter your loads and all required design parameters.
  2. Optimise design
    In the right-hand panel, under Notifications, PROFIS Engineering may display suggestions to improve your design.
    Click Optimise in the recommended prompt to apply the suggested adjustment.
Use Smart Design to explore multiple solution options. This can help you quickly identify a configuration with better utilisation, geometry, or product selection.
