How to define longitudinal reinforcement in existing concrete member in Post-installed rebar module
Defining the longitudinal reinforcement in the existing concrete member allows PROFIS Engineering to accurately model the reinforcement that the post-installed rebar will splice into. Providing precise reinforcement details ensures correct calculation of development length, anchorage behaviour, and load transfer in the Post‑installed Rebar module.
  • Have opened the Post-installed rebar module
If needed, refer to the article How to access the Post-installed rebar module in PROFIS Engineering.
  1. Open the Existing reinforcement tab
    In your Post-installed rebar design workspace, navigate to the Existing reinforcement tab on the left-hand side of the screen.
  2. Select the format for entering reinforcement details
    Under Longitudinal reinforcement, choose whether you want to define reinforcement using Reinforcement layers or Reinforcement arrangement.
    Enable Changes in cast-in rebars affect post install rebar positions if applicable.
  3. Enter reinforcement details
    If Reinforcement layers is selected, enter the following parameters: Shape, Bond condition, Front cover and no. of layers.
    For each layer specify: Diameter, Bar arrangement and Top cover.
    If Reinforcement arrangement is selected, enter the following parameters: Shape, Bond condition, Diameter, No. of bars in x and y direction, Side cover and Front cover.
Note: For End anchorage connection the longitudinal reinforcement input is not available.
