How to modify default parameters
Modifying the default parameters allows you to customise PROFIS Engineering to match your preferred design settings. These defaults help streamline your workflow by automatically applying your chosen values to every new project.
  3. Open the Setting menu
    Click the settings icon (⚙️) in the top-right corner of the screen.
  4. Navigate to Default parameters
    In the left-side menu, go to General → Default parameters.
  5. Modify default parameters
    Under Default parameters, adjust the values as required for your workflow.
  6. Save your settings
    Your changes will be applied immediately.
Setting default parameters that reflect your typical project requirements can save time and help maintain consistency across all your new designs.
