Quick start configurations
Quick start configurations allow you to set up PROFIS Engineering with your preferred region, design codes, units, and default parameters before beginning any project. Completing these steps ensures your designs automatically align with the correct standards and reduces the need to adjust settings manually for each new design.
Make sure you are logged in to your PROFIS Engineering account.
  1. Open the PROFIS Engineering website
    Open your browser and navigate to: https://profisengineering.hilti.com
  2. Open the settings menu
    Click the Settings icon located at the top‑right corner of the screen.
  3. Select your default region
    In the pop-up window, navigate to General → Region and language.
    Choose your Region to automatically apply the relevant anchor portfolio, design codes, unit system, and safety factors.
  4. Choose your preferred language (Optional)
    Under General → Region and language, select the Language you want the user interface to display.
    This helps ensure clarity while navigating menus and workflows.
  5. Set your default design parameters
    Go to General → Default parameters.
    Update any default design settings you want applied to all new designs, such as:
    • Design method
    • Safety factors
    • Steel calculation method (available for select modules)
    • Advanced baseplate calculation settings (available for select modules)
  6. Adjust unit settings
    Under your selected design module in the left‑side panel, open Units and default parameters to customise.
    These units are initially tied to your selected region, but you can customise them as needed.
  7. Modify interaction settings (Optional)
    If desired, you can change how the 3D model responds to your mouse controls by accessing:
    General → Interaction settings.
    This lets you set your preferred rotate, pan, and zoom controls.
  8. Save your settings
    All changes are applied immediately.
    You can now begin designing with the correct region, units, and default parameters already configured.
Quick Start Configurations are especially useful if you work on multiple projects with similar code requirements. Setting up your region, units, and default design parameters at the start will save time and help maintain consistency across all your designs.
