How to modify interaction settings
Modifying the interaction settings allows you to customise how you rotate and pan the 3D model in PROFIS Engineering. These settings let you assign your preferred mouse actions, helping you navigate and manipulate the model more efficiently during your design workflow.
  3. Open the Setting menu
    Click the settings icon (⚙️) in the top-right corner of the screen.
  4. Navigate to Interaction settings
    In the left-side menu, go to General → Interaction settings.
  5. Modify interaction settings
    Under Interaction settings, adjust as needed.
  6. Save your settings
    Your changes will be applied immediately.
