How to select interface to structural connection software
0
Selecting the interface to structural calculation software allows PROFIS Engineering to exchange data with external analysis tools such as Dlubal, SAP2000, RISA, ETABS, and others. Enabling these interfaces helps streamline your workflow by allowing structural connection data to be transferred directly between PROFIS Engineering and your chosen analysis software.
  3. Open the Setting menu
    Click the settings icon (⚙️) in the top-right corner of the screen.
  4. Navigate to Interfaces to structural calculation software
    In the left-side menu, go to General → Interfaces to structural calculation software.
    Note: Only RAM is available for Standard users. All other options can be accessed only by users who are subscribed to PROFIS Engineering Premium.
  5. Choose your interface
    From the available options, select your preferred interface.
  6. Save your settings
    Your changes will be applied immediately.
Enable only the interfaces you actively use to keep your application settings clean and reduce unnecessary integration prompts. If your structural engineer or project team relies on a specific analysis software, confirm the required interface in advance to ensure smooth data compatibility.
