How to create a new PROFIS Engineering design file
Creating a new design file allows you to start a project with the appropriate design module, fixing type, region, and default settings. Configuring these options at the beginning ensures that PROFIS Engineering applies the correct codes, units, and calculation methods throughout your workflow.
  3. Create a custom design
    Click New in the top-left corner of the screen.
    From the dropdown list, select Custom design.
  4. Select the design module
    In the pop-up window:
    • Enter a design name.
    • Select location where the file will be saved.
    • Choose your region.
    • Select fixing type (e.g., Concrete to concrete, Facade)
  5. Modify default design methods and units (Optional)
    In the same window, you can update:
    • Design method
    • Units
    • Safety factors and default parameters
    • Steel calculation method and parameters
    • Advanced anchor plate calculation settings
      Use arrow on the right, to expand or collapse a section.
      Note: Some options in this menu are available only for specific design modules.
  6. Save your settings
    Click Save to create your new design file and open your workspace.
Set your preferred region, units, and design methods before starting multiple designs. This ensures consistency across your workflow and reduces the need to adjust settings for each new project.
