How to select post-installed element and define layout in Shear strengthening module
Selecting the correct post‑installed strengthening element and configuring its layout ensures that PROFIS Engineering models the shear strengthening system accurately. These inputs determine post-installed element capacity, spacing, installation direction, and behaviour across different strengthening zones.
  • Have opened the Shear strengthening module
  • Have defined Concrete geometry and the Number of Zones under the Base Material tab
If needed, refer to the article How to access the Shear strengthening module in PROFIS Engineering.
  1. Open the Post-installed element tab
    In your Shear strengthening design workspace, navigate to the Post-installed element tab on the left-hand side of the screen.
    Here you can define the strengthening elements and Zones.
    Select the Post‑Installed Strengthening Element
  2. Choose the product family
    Under Family, select the desired injection system + fastening element combination.
    Use the arrow icon to browse available families.
  3. Select the product type
    Use the Type dropdown to pick the specific product.
    This section gets automatically updated based on your product family selection.
    You may click View approval to review product approval document.
  4. Select the size of post-installed element
    Choose the appropriate Size from the dropdown.
    The post-installed element diameter affects:
    • Drill hole size
    • Embedment depth
    • Spacing and edge distance limits
Define the Strengthening Layout for Each Zone
After selecting the element, expand the Zone section to configure layout parameters. You can modify number of zones in the base material tab.
  1. Enable strengthening elements
    Check Define strengthening elements to activate the zone.
    Each active zone allows independent layout configuration.
  2. Select the installation direction
    Use the Installation direction dropdown to choose from:
    • Configuration A
    • Configuration B
    • Configuration C
    Click the information (i) button to view diagrams explaining installation direction options, including which sides of the element can be drilled depending on support conditions (end support, intermediate support, foundation, etc.).
  3. Define spacing
    Enter the required spacing:
    • Spacing in x
    • Spacing in y
    Use + / – buttons or type values manually.
    Spacing influences shear capacity distribution.
  4. Define minimum edge distances
    Enter:
    • Min. edge distance in x
    • Min. edge distance in y
  5. Define transverse eccentricity
    Enter Transverse eccentricity as needed.
    Click the information (i) button to view diagrams showing how eccentric placement reduces the effective shear width of the concrete section.
  6. Repeat for additional zones
    If your strengthening design includes multiple regions, repeat steps 5 to 9 for each zone as required by the project.
Use the information (i) buttons frequently, especially for installation direction and transverse eccentricity. These pop‑ups provide clear visual guidance and ensure your strengthening layout aligns with actual support conditions and post-installed element behaviour.
