How to modify anchor layout in Concrete-over-metal-deck module
Modifying the anchor layout allows PROFIS Engineering to correctly represent the position and spacing of anchors on the metal deck.
  • Have opened the Concrete-over-metal-deck module
If needed, refer to the article How to access the Concrete-over-metal-deck module in PROFIS Engineering.
  1. Open the Anchor tab
    In your Concrete-over-metal-deck design workspace, navigate to the Anchor tab on the left-hand side of the screen.
  2. Open the Layout section
    Expand the Layout section to view the available inputs.
  3. Select the anchor layout
    Choose the desired anchor layout from the available options.
