How to save your design as template in Concrete-over-metal-deck module
Creating a design template allows you to reuse your preferred design inputs, so you don’t need to start from scratch each time you create a similar connection.
  • Have opened the Concrete-over-metal-deck module
  • Have entered all required design inputs
If needed, refer to the article How to access the Concrete-over-metal-deck module in PROFIS Engineering.
  1. Click the Save as template icon
    In your Concrete-over-metal-deck design workspace, go to the top panel and select the Save as template icon.
  2. Name your template
    In the pop‑up window, enter a name for your template and click Save.
Creating templates for your commonly used connection types can save time and help standardize your design process.
