How to create a new project
Creating a new project in PROFIS Engineering allows you to organise your design files under a dedicated project workspace. This helps you keep related designs together, streamline project management, and quickly locate all files associated with a specific job or client.
  3. Create a new project
    Click New in the top-left corner of the screen.
    From the dropdown list, select Project.
  4. Name your project
    In the pop-up window, enter the Project name and click Save.
  5. Accessing your project
    In the PROFIS Engineering home page, go to My projects on the left-hand side of the screen and click on your project folder.
Use clear and consistent naming conventions, such as project number, client name, or structure type, to make your projects easy to find later. Creating subfolders within each project can further help you organise multiple design iterations or connection types.
