Navigating the landing page for Shear strengthening module
Upon logging into PROFIS Engineering module, the 3D model is displayed centrally within the workspace. The left panel is designated for entering design inputs, the bottom panel facilitates the management of load combinations, and the right panel presents results, notifications, and options for generating design reports, specification texts, as well as basic import/export functionalities.
  • Have opened the Shear strengthening module
If needed, refer to the article How to access the Shear strengthening module in PROFIS Engineering.
Overview of the interface
Home button
Favourites
Save and access commonly used design inputs.
Application
Select your application
Base material
Enter information related to concrete grade, geometry, temperature, strengthening zones and openings.
Existing reinforcement
Specify material strength and reinforcement details.
Installation conditions
Specify drilling type, hole type and drilling aid.
Post-installed element
Define product, fastening element, size, layout and spacing.
Load/calculation type
Select load type and design method.
Bottom panel (Load combinations)
Use this panel to input, edit, and manage load combinations acting on the connection.
Export
Export your design in a variety of formats.
Specification text
Generate specification text summarising project‑specific design inputs.
Importing existing file
Zone wise design details
Expand to view design checks and utilisation results.
Notifications
View design tips, watchouts, and system messages.
Top panel (Settings & tools)
Settings
Modify design method, units, and safety factors.
Save as template
Support
Learn
Updates
Profile
View your profile, manage your account, view legal documents, and sign out.
Central panel (3D view)
The 3D model of your design is displayed in this area. You can adjust the view, modify geometry, apply loads, and select products directly within the 3D environment.
Reset camera
Return the model to the default viewing position.
Show/hide elements on 3D
Control what is displayed in 3D view. You can choose to show or hide concrete and strengthening element details.
Undo
Reverse the previous action.
Redo
Zoom to fit
Automatically fit the entire model within the screen.
Collapse menu
Collapse or expand the left-hand, right-hand or bottom panel for more workspace visibility.
Zoom
Zoom in or out of the 3D model.
