How to use the 3D Editor in Shear strengthening module
The 3D view allows you to adjust the visual orientation of your model and edit geometry directly - all within an interactive 3D environment.
  • Have opened the Shear strengthening module
  • Have enabled the 3D editor
If needed, refer to the article How to access the Shear strengthening module in PROFIS Engineering.
  1. Modify dimensions
    In the 3D view, click directly on any dimension label to edit.
  2. Modify the view
    Rotate: Left‑click and drag anywhere in the 3D view.
    Pan: Right‑click and drag to shift the model.
Use Show/hide elements in 3D to control what is displayed.
For more details, refer to the article Navigating the landing page for shear strengthening module to familiarise yourself with all available controls.
