How to save your design as template in Anchor channel module
Creating a design template allows you to reuse your preferred design inputs, so that you don’t need to start from scratch each time you create a similar connection.
  • Have entered all design inputs
  1. Click the Save as template icon
    In your Anchor channel design workspace, go to the top panel and select the Save as template icon.
  2. Name your template
    In the pop‑up window, enter a name for your template and click Save.
Creating templates for your commonly used connection types can save time and help standardise your design process.
