How to save PROFIS design file in Anchor channel module
Saving your design file in PROFIS Engineering ensures that all project inputs, design parameters, and results are stored securely for future editing, review, or reporting. This allows you to continue your design workflow later, share the file with colleagues, or use the saved design as a template for similar projects.
  • Have entered all design inputs
  1. Click the Export icon
    In your Anchor channel design workspace, go to the panel on the right-hand side of the screen and click the Export icon.
  2. Save the PROFIS design file
    From the export options, choose PROFIS file to device.
    The file will be automatically saved to your downloads folder or your predefined system folder.
For repeated use, it is recommended to save a clean version as a template to facilitate the quick initiation of new designs with consistent default settings. To easily locate and reuse files, implement a clear naming convention that includes details such as project name, location, and solution type. Additionally, it is advisable to save the printed report to monitor any changes resulting from future improvements in PROFIS Engineering releases when re-importing the design file.
