How to import existing PROFIS design file in Anchor channel module
0
Importing an existing design file in PROFIS Engineering allows you to reopen a previously saved project so that you can review, edit, or continue working with the original inputs, design parameters, and results.
  1. Click the Import icon
    In your Anchor channel design workspace, go to the panel on the right-hand side of the screen and click the Import icon.
  2. Import the PROFIS design file
    Navigate to the folder where your existing PROFIS design file is stored.
    Select the file you want to import to open it in PROFIS Engineering.
