How to define favorite inputs in Anchoring to Concrete module
Favorite inputs allow you to quickly access the design parameters you use most often, helping you streamline your workflow and reduce repetitive navigation across different tabs.
  1. Open the Favorites tab
    In your Anchoring to Concrete design workspace, navigate to the Favorites tab on the left-hand side of the screen.  Here you can view all inputs currently marked as favorites.
  2. Add or remove favorite inputs
    Go to any design input tab on the left.
    Click the star icon at the top of the input panel to add it to Favorites.
    Click the star icon again to remove it from Favorites.
You can rearrange your favorite inputs by right-clicking an item and dragging it to your preferred position. This helps organize your workflow for faster access to frequently used settings.
