How to define and modify installation conditions in Anchoring to Masonry module
Defining the installation conditions ensures that PROFIS Engineering applies the correct drilling method and borehole condition, so that anchor performance reflects realistic installation practices used on site. These two inputs tell the software how the hole is made and what condition it’s in, so it can use the correct capacities from approvals and test data.
  1. Open the Base material tab
    In your Anchoring to Masonry design workspace, navigate to the Base material tab on the left-hand side of the screen.
  2. Select the drilling type
    Under Installation conditions, choose the appropriate Drilling type from the dropdown menu.
    Note: Drilling type refers to the method used to create the hole in the concrete. This influences the surface roughness and geometry of the hole, which in turn affects the bond and anchor performance, thereby impacting the design strength.
  3. Select the borehole condition
    Under Borehole condition, choose the appropriate Hole type from the dropdown menu.
Based on the selected installation methods, PROFIS Engineering will automatically filter the applicable products. To ensure the expected performance at the job site, adherence to the specified installation method is required. Consequently, this constitutes an important aspect of the specification for the installer to comply with.
