Navigating the landing page for Diaphragm Design module
Upon logging into PROFIS Engineering module, the 3D model is displayed centrally within the workspace. The left panel is designated for entering design inputs, the bottom panel facilitates the management of load combinations, and the right panel presents results, notifications, and options for generating design reports, specification texts, as well as basic import/export functionalities.
  • Have opened the Diaphragm Design module
If needed, refer to the article How to access the Diaphragm Design module in PROFIS Engineering.
Overview of the interface
Home button
Areas
Enter information related to design method, deck properties, joist beam properties and side lap connectors.
Bottom panel (Load combinations)
Use this panel to input, edit, and manage zone as well as load acting on the connection.
Save
Save your design file or generate specification text.
Duplicate
Generate a duplicate copy of your design.
Importing existing file
Area summary
Expand to view loads acting on each area.
Messages
View design tips, watchouts and system messages.
Top panel (Settings & tools)
Settings
Modify design method, units and safety factors.
Save as template
Support
Learn
Updates
Profile
View your profile, manage your account, view legal documents, and sign out.
Central panel (3D view)
The 3D model of your design is displayed in this area. You can adjust the view, modify geometry, apply loads, and select products directly within the 3D environment.
Reset camera
Return the model to the default viewing position.
Show/hide elements on 3D
Control what is displayed in 3D view.
Undo
Reverse the previous action.
Redo
Zoom to fit
Automatically fit the entire model within the screen.
Collapse menu
Collapse or expand the left-hand, right-hand or bottom panel for more workspace visibility.
Zoom
Zoom in or out of the 3D model.
Area
Switch between different Areas.
Zone
Switch between different Zones.
Load
Switch between different Loads.
Product selector
Select frame fastener, sidelap fastener and view product approval information.
