How to use the 3D Editor in Post-installed rebar module
The 3D view allows you to adjust the visual orientation of your model, edit geometry directly, apply loads, and select products - all within an interactive 3D environment.
  • Have opened the Post-installed rebar module
  • Have enabled the 3D editor
If needed, refer to the article How to access the Post-installed rebar module in PROFIS Engineering.
  1. Modify dimensions
    In the 3D view, click directly on any dimension label to edit.
  2. Input loads
    Click on the tension, shear, or moment load labels in the 3D view to enter load values.
  3. Select product
    Click the product selector box in the top right corner of the 3D view to choose the product type, size, rebar grade, and to view product approval data.
  4. View Sustainability related information
    Expand the sustainability tab to view CO2 emissions.
  5. Modify the view
    Rotate: Left‑click and drag anywhere in the 3D view.
    Pan: Right‑click and drag to shift the model.
    Note: 3D model rotation button is included in new concrete tab.
For more details, refer to the article Navigating the landing page to familiarise yourself with all available controls.
