How to define and modify concrete geometry in Shear strengthening module
Defining and modifying the concrete geometry ensures that PROFIS Engineering uses the correct member dimensions and edge distances for accurate shear strengthening design and realistic load‑transfer behaviour.
  • Have opened the Shear strengthening module
If needed, refer to the article How to access the Shear strengthening module in PROFIS Engineering.
  1. Open the Base material tab
    In your Shear strengthening design workspace, navigate to the Base material tab on the left-hand side of the screen.
  2. Go to Concrete geometry
    Here you can type in the length, width, and height of the concrete member. Alternatively, use the “+ / –” controls to increase or decrease the values.
