How to use the 2D Editor in Concrete overlay module
The 2D view allows you to edit base material geometry, view zone analysis, and select products - all within an interactive 2D environment.
  • Have opened the Concrete overlay module
  • Have enabled the 2D editor
If needed, refer to the article How to access the Concrete overlay module in PROFIS Engineering.
  1. Modify dimensions
    In the 2D view, click directly on any dimension label for base material to edit it.
    Tip: Make sure the select button is enabled prior to editing.
  2. View zone analysis
    Click on the arrow to expand and view zone analysis.
  3. Select product
    Click the Shear connector box in the top right corner of the 2D view to choose the product type, size, view length, and to view product approval data.
  4. Modify the view
    Pan: Click the Pan model button to drag and reposition the model.
    View mode: Toggle between top view, side view and front view as needed.
  5. Modify grid settings
    Open Layout on the left-hand panel.
    Modify Grid spacing as required.
    Enable or disable Show grid.
Use Show/hide elements in 2D to control what is displayed.
For more details, refer to the article Navigating the landing page to familiarise yourself with all available controls.
