How to open an existing PROFIS Engineering design file
Kamalika Kundu
Kamalika Kundu
Opening an existing design file allows you to continue working on a previously saved project, review past design inputs, or generate updated reports without starting from scratch.
  3. Open the design file
    In the left-hand navigation panel, select Drag & drop or choose file.
    You can either:
    • Drag and drop your PROFIS design file into the upload area, or
    • Click Choose file and select the file from your device.
