How to search for a design file in PROFIS Engineering
Searching for a design file in PROFIS Engineering helps you quickly locate previously created projects without manually browsing through folders. The search function allows you to filter and access your designs efficiently, ensuring a smoother workflow, especially when working with multiple projects.
  3. Search for a design file
    In the PROFIS Engineering home page, navigate to search bar under All designs.
    Choose to view the search results either in grid view or list view.
  4. Sort the design files
    Click on Sort and select suitable option from the dropdown list to sort the design files.
Use specific keywords such as project name, file name, or client reference to narrow down your search results. Keeping a consistent naming convention for your design files will make them easier to find later.
