How to change the design region and design method when duplicating an anchor plate design.
Premium users can duplicate an existing Anchor plate design and select a different design region and code for the duplicated design. When creating the copy, you can retain the existing settings or select a different Location, Country, Standard, and Design method.
  • Have a Premium subscription
  • Have opened an existing Anchor plate design in the Anchoring to Concrete module
  1. Open the Export tab
    In the design you want to duplicate, go to the Export tab.
PROFIS Engineering Anchor plate design with the Export tab highlighted.
  1. Select Duplicate
    In the Export As menu, select Duplicate.
EXPORT AS menu in PROFIS Engineering with Duplicate highlighted.
  1. Enter the design name
    In the Duplicate File window, enter a name for the duplicated design.
Duplicate File window in PROFIS Engineering with the Design name field highlighted.
  1. Select the design settings
    Keep the existing settings or select a different Location, Country, Standard, or Design method.
Duplicate File window in PROFIS Engineering with the Location, Country, Standard, and Design method fields highlighted.
  1. Create a copy
    Select Create a copy.
    • If you retain the original Location, Country, Standard, and Design method, the design opens directly in a new window. Continue working on the duplicated design in the new window.
    • If you change any of these settings, the Duplicate Design Status pop-up opens in the new window. Continue to Step 6.
Duplicate File window in PROFIS Engineering with Create a copy highlighted.
  1. Review the copied parameters
    If you changed the Location, Country, Standard, or Design method, review the following parameters copied from the source design:
    • Concrete size
    • Loads
    • Baseplate size
    • Anchor layout
    All other parameters are reset to the default values for the selected design region.
    Adjust the parameters as needed, then select Continue to work on the duplicated design.
Duplicate Design Status window showing the parameters copied from the source design and Continue highlighted.
Notes
  • If a parameter cannot be mapped to the selected design region, a warning symbol is displayed, and the parameter is set to its default value in the duplicated design.
  • Available features and products depend on the selected country. Check the corresponding country settings for availability.
