How to optimize your design in Anchoring to Concrete module
Optimizing your design allows you to improve anchor performance by adjusting key parameters such as anchor layout or anchor plate dimensions. Small changes to these inputs can help you achieve a more efficient design.
  1. Input design parameters
    In your Anchoring to Concrete design workspace, enter your loads and all required design parameters.
  2. Optimize design
    In the right-hand panel, under Notifications, PROFIS Engineering may display suggestions to improve your design.
    Click Optimize in the recommended prompt to apply the suggested adjustment.
Utilize Smart Design to evaluate multiple solution options with different anchors. This approach can facilitate rapid design improvements by optimizing both the anchor layout and anchor plate geometry.
