How to modify borehole conditions in Anchoring to Concrete module
Modifying the borehole condition ensures that PROFIS Engineering applies the correct surface characteristics when evaluating anchor performance.
  1. Open the Base material tab
    In your Anchoring to Concrete design workspace, navigate to the Base material tab on the left-hand side of the screen.
  1. Go to Borehole condition
    Select the desired Borehole condition from the dropdown menu.
Borehole conditions can influence anchor capacity. Updating this setting whenever jobsite conditions change helps maintain accurate design assumptions.
