How to use the 3D Editor in Concrete to Concrete module
The 3D view allows you to adjust the visual orientation of your model, edit geometry directly, apply loads, and select products - all within an interactive 3D environment.
  • Have opened the Concrete to Concrete module
  • Have enabled the 3D editor is enabled
If needed, refer to the article How to access the Concrete to Concrete module in PROFIS Engineering.
  1. Modify dimensions
    In the 3D view, click directly on any dimension label to edit.
  2. Input loads
    Click on the tension, shear, or moment load labels in the 3D view to enter load values.
  3. Select product
    Click the product selector box in the top right corner of the 3D view to choose the product type, size, rebar grade, and to view product approval data.
  4. Modify the view
    Rotate: Left‑click and drag anywhere in the 3D view.
    Pan: Right‑click and drag to shift the model.
    Note: 3D model rotation button is included in new concrete tab.
Load input or products available might be affected by the connection type selection (Lap splice, structural Joints or Shear doweling)
For more details, refer to the article Navigating the landing page to familiarize yourself with all available controls.
