How to define the metal deck type in Concrete-over-metal-deck module
Selecting the correct metal deck type ensures that PROFIS Engineering applies the appropriate deck geometry, flute orientation, and structural configuration for concrete‑over‑metal deck applications.
  • Have opened the Concrete-over-metal-deck module
If needed, refer to the article How to access the Concrete-over-metal-deck module in PROFIS Engineering.
  1. Open the Base material tab
    In your Concrete-over-metal-deck design workspace, navigate to the Base material tab on the left-hand side of the screen.
    Define Metal deck type
  2. Open the Metal deck type section
    Expand the Metal deck type section to view the available inputs.
  3. Select the Metal deck
    Select the deck profile from the dropdown.
  4. Choose the Anchor position
    Select the Anchor position from available options.
