How to save your design as template in Diaphragm design module
Creating a design template allows you to reuse your preferred design inputs, so you don’t need to start from scratch each time you create a similar connection.
  • Have opened the Diaphragm Design module
  • Have entered all required design inputs.
If needed, refer to the article How to access the Diaphragm Design module in PROFIS Engineering.
  1. Click the Save as template icon
    In your Diaphragm Design workspace, go to the top panel and select the Save as template icon.
  2. Name your template
    In the pop‑up window, enter a name for your template and click Save.
Creating templates for your commonly used connection types can save time and help standardize your design process.
