How to import existing PROFIS design file in Diaphragm Design module
Importing an existing design file in PROFIS Engineering allows you to reopen a previously saved project so you can review, edit, or continue working with the original inputs, design parameters, and results.
  • Have opened the Diaphragm Design module
If needed, refer to the article How to access the Diaphragm Design module in PROFIS Engineering.
  1. Click the Import icon
    In your Diaphragm Design workspace, go to the panel on the right-hand side of the screen and click the Import existing file icon.
  2. Import the PROFIS design file
    Navigate to the folder where your existing PROFIS design file is stored.
    Select the file you want to import to open it in PROFIS Engineering.
